ok so i have already changed the alternator and i still have this problem…
i keep blowing the alternator fuse…
its funny if i jiggle around the plug it will work fine… but i dont want it to leave me stranded… so far ive had the luck that it does it in my house only…
how can i check if a wire is creating a short inthere somewhere…
or how can i fix it…
pls help guys… maybe if ya would like to call and explain. i will be outside trying to find a solution…
the alt. fuse is not in the engine bay its next to the kick panel…
and the plug that im talking about is the green one that plungs into the alt. that has three wires run out of it…
im wondering if the plug themselfs can get fu@@ed up…
well when the problem first started i tried many things…
at the end i did change the alt. and yeah it did work for about two days and then started to do the same thing…
this is when i knew it wasnt the alt…
and thats when i found out that if i jiggle the wires from the plug it would work… the plug itself looked fine, but yesterday i went to the junk yard and got a plug…
i put it on and i drove all of last night and it was fine…
so im guessing it was the plug but i will keep you guys posted…
