amp power wire install???
implanning on installin my sub into my da this weekend and idk where the eaiest place to run the power wire threw .my friend told me that he drilled a hole in his fire wall i want to try avoiding that but if that is the easiest way if some one could take a pic i would appericate it or give me an easier route THANKS !
on the passenger side i ran it through where the all the wires go through…i cut a hole in the gorment and fished it through with a metal coat hanger.
that would be on the door right??
no. on the passenger side of the firewall. there should be a couple to choose from, depeding on the options your car has.
on my last teg, I used to gromet under the brake booster.
thanks guys did ths last night used that gromet and worked perfect!!
