Long story short I’ve been having idling problems since i got the car! It’s a 91 Da b20b4 swap. B18a1 intake manifold 90-91 version and b18a1 exhaust manifold. the car has had many different idle’s depending on what I’ve done and changed on it and here are the symptoms I’ve gone through!
Symptoms: high idle 1500-2500 not bouncing just depening on if it was a cold start or warm idle. car bog down below 3500 rpm and then come to life after 3500. car would sputter randomly and was wasting gas like a v12
Taking off the IACV anc blocking it off has made the car idle normal at 800-900 (normal compared to what it use to idle at) It’s giving the IACV code so I installed a good / used IACV and now my idle is back at 1500 even with the Idle adjustment screw all the way closed.
My distributor is not fully advanced so it’s not that
So here’s what I’ve changed from maintenance to solving problems
New distributor
All new vac hoses
Throttle body gasket and Intake manifold gasket
Thermostat (did the bleeding process mulitple times to make sure no air was trapped)
Spark plug wires and spark plugs (multiple times on the plugs)
Fitv is competley blocked off
o2 sensor.
fuel pump and fuel strainer
I am getting about 30-35 mpg on the freeway so It’s good now but since i’ve connected the IACV again its idling at 1500-2000 so now im killing gas again.
My next move is to change the intake manifold to a b18a1 92-93 and I have a new throttle body that im going to use also after that if it doesn’t change than I’ve litteraly changed every single part on the car that has to do with air entering the engine besides the head it self. Let me know what you guys have to say and if you’ve done this your self. Also going to put a new fuel pressure regulator
The only code I’m throwing is the egr code cause I’m using a auto Pr4 ecu at the moment.
Also my fuel level low light stays on no matter what level fuel I have, I’ve changed the gas gauge, fuel floater and fuel pump. The fuel floater was pretty new my friend just bought it (new) not too long ago for his integra and the fuel pump as well he Is using a fuel cell now so he gave me these parts.
