all new mounts
popping when i turn corners
and vibrating in all forward gears but not in reverse
what could it be?
all new mounts
what could it be?
Sounds like axles to me with the popping/clicking noise when turning, i’m having the same problem with the vibrating when accelerating but I still don’t know for sure what it could be. It also could be a tire is out of balance or rim is bent. Or bad axle. I’ve read the threads and theres a couple other things it could be. The bad thing is with our old tegs it’s probably a little bit of everything. Keep us up to date if you get everything working.
