Another Fitment Question Thread (15x8 et20)
So while browsing for wheels randomly today I stumbled upon some wheels that I really like. They are XXR 532’s in 15x8 et20 with the gold finish. My car is lowered about 2 inches on Tein S-tech springs with Skunk 2 camber adjustments at all 4 corners. I’m trying to figure out what tire size I would need to run while not rubbing and or need to do extensive fender work. I also found another set of wheels in 15x7 but et15 and I don’t know if that would put the wheel to far out but being as they’re a 7 inch wide wheel it would most likely be a little easier to find rubber for it. Basically my question is will they work, and what tire sizing would work for either set up while maintaining relative speedometer accuracy.
Www.rimtuck.com
That site is a decent resource for seeing what to expect when choosing a wheel and tire package.
Well a small update, I can get the right rolling radius using a 205/50R15 tire. This fitment stuff is not really my cup of tea but I may just have to bite the bullet and try them out. Then again it could be a $1000 oops. Damn you tough decisions!
Thats a pretty expensive “try out” to bargain with. There is another thread on here specifically for DAs with low offset wheels. Browse through it and see if there is something that you like.
