So I’ve been reading all the threads on here reguarding antennas relocation and such. I have purchased the cap from the 90-93 Accord. I was debating on the internal antenna or movie it up to the rear window washer squirter. I may later do the rear window washer squirter. But for the time being, I removed the antenna. I unplugged the 2 wires, positive and negative, but left the wire from the radio plugged in. I wire tied it in the area it was originally located just a bit lower so it’s not sticking out of the whole. Since I disconnected to 2 wires, it no longer goes up and down and I still get good reception. Does anyone see any issues with this??
i dont see any problem with it as long as you A.) still get good reception and B.) have the wires that you disconnected secured and covered up. what style/type antenna do you plan on using if you relocate it to the upper washer nozzel? i too have been planning on relocating it there, just cant put my thumb on what i want up there…
bump for same here!
