my “anti-lock” light came on, the abs doesnt work anymore, what should i do??.. how do i read the the codes? i have the book but i dont get how the codes work… please help.
If you have the book, read carefully where it explains how to read the codes and then what the codes mean.
Usually, when you turn the ignition key on LED blinks on ABS ECU. It gives a series of blinks, which means the code. You have to count them.
i’ll try…
whenever i slam the brakes hard my abs light will come on…and stay on…sometimes even i just brake normal it does
after i turn the car off then turn it back on again it goes away? ![]()
