Anti Lock Light
I have the anti lock light on since i locked up the wheels one time, i checked where in teg tips it tells you how to diagnose the problem but im not seeing any blinkin coming from the whole that the light is supposed to be in. Any ideas?
it’s better to check in the evening as that tiny LED light is hard to see during the day… you also have to look at it in an akward position to see it clearly… you kinda have to lay your head down on the passenger seat to see it…
i was lookin at it in almost pitch dark where if htere wus a slite change in lite i shoulda oticed it
I’ll provide you some pictures…
after you’ve driven around, turn off your car to the on position… then turn it to the acc position… this will activate the LED light from your ABS computer…
http://www.ncraspeed.com/integ115/pic1.gif
http://www.ncraspeed.com/integ115/pic2.gif
http://www.ncraspeed.com/integ115/pic3.gif
Im doin everythin rite i even see where the LED is but it jsut dosent blink.
Try uncapping then recapping the ABS brake fluid resevoir. My light came on a couple of weeks ago, so I thought I was low on fluids. I uncapped the ABS reservoir, saw that it was full, then recapped it. After that, light’s been out. Maybe relieved some pressure?
Just in case you’re not sure, its the yellowish resevoir on the passenger side of the engine compartment.
checked the fluid already neither is it low nor did it help
