Ive just found out the front passenger side sway bar on the da is bent.
now do i -
- Heat it up to try and straighten it.
- Try and find another 1 and if so which honda other than a da shares the same sway bar.
the previous owner obviously hit a kerb with the front passenger side wheel causing a bent front lower control arm,bent sway bar,which left the wheel all pushed back.
i bought 2 brand new front lca’s for it under the impression they would fit as they were advertised as crx vtec items,so when it came to fitting them everything apart from the sway bars were fitting.the bolt holes for the sway bars are slightly off.
I’m desperate to get this on the road but everytime i go near it i’m finding more wrong with it. ![]()
