Originally posted by spikeymike
[B]your not SOL, just because you have a 90-91 doesn’t mean you can’t change the stock fog light bulbs. its just a matter of changing the connector either to the bullet type(round one) or spade(flat). in otherwords your not stuck with the stock ones. you can put any h3 in, just change the connector accordingly.
if the 90-91 stock h3’s has a bullet connector stock, and the new h3 you get has a spade connector, then just go out and get some bullet connectors and crimp them onto the new h3’s. [/B]
Where would the best place be to find the connectors to do the mod right?
Funny I stumbled upon this right after I did it. I got the Sylvania Silverstar H3s just today and noticed that the connector was flat and the stock was rounded. After closer inspection, the “female” end or the one connected to the car isn’t an “O”, it’s more of a “C” so the aftermarket bulb still fit in, just fit in like " C- " rather than " Co" The connector is close enough together that I’ll pinch the flat male connector between in and hold it inside. Works wonderfully. Now I have silverstar heads/fogs. People are really gonna bright me now.
at first i was freaking out everywhere I went had a dam flat type connector. I told them how stupid they were and everything. I was like :wtf: . I said screw you guy i’m going on g2ic. and sure enough stumbled on this post stating,"
I thought to myself plug and play??:gtfo:
There was no need for converting anything in my situation just slapped that sumbich in there. all that :rant: for nothing… anyways koodles to metallicseafoam
