For almost a year I have solely relied on my Ipod for music because my car has no antenna. It’s been removed and the hole has been plugged. I’ve been tinkering with the idea of an antenna on the roof like the Toyota Corolla or the older model VW GTI 16v. Has anyone tried something like this or have any other ideas to share. I’m all ears.
You can do that or get an antenna from the Honda S2000 and just drill a hole wherever you want and just wire it up OR you can go with those hidden antenna where you hide the receiver inside your cabin if you want the clean antenna-less look…
Thanks. I’ll do a little research on that.
There was a member from Team-Integra (granted it was a 3rd Gen) got a hot rod antenna and hid it above the headliner by the hatch so that it was up high for better reception, I’ve been planning to do this when I repaint and remove the stock antenna since the motor is out.
Hope this helps with a new Idea.
I found similar on ebay searching for hot rod antenna I think
Get an amplied/power antenna and stick it under your dash.
I found the Auto loc hidden antenna. It’s amplified and can be stashed under the dash. I’m going with that one.
Yup those are the ones I was talking about… I would have gone with those hidden ones but didn’t want to deal with sealing up the stock antenna hole…
