any way to defeat the wind noise from windows?
topic…
the only thing I can suggest is to get new rubber seals.
Sometimes those damn windows fall out of the seals… and the wind gets REALLY loud.
I always wind the window down slightly, open and close the door, then wind it back up… so that the window slides into the rubber seal.
I think that there are adjusters in you doors to change the angle of your window. Over time they have shifted slightly, not allowing the window to seal with the rubber. You’d have to search to find out exactly how to adjust it or maybe someone will see this and know.
If the window isn’t tracking right you’ll have to remove the door panel to get to the adjusting nuts. I think there is 2 or 3 nuts.
There’s a solution in Teg Tips:
http://www.g2ic.com/tegtips/exterior/#windowfix
I did it. Fixed things right up for me.
