Is this even possible? Wouldn’t mind switchin these two around but I don’t even know if this is possible, just throwin stuff out there.
bumper lights into fogs would look good cause of their position but the fogs into signals would look like a saturn lol
True. I mean anything to replace the fogs that get moved. I wouldn’t even want to put signals I was just throwin some stuff out there. Even having those lights as constant on lights just like the headlights would be good. The 92-93 bumper lights are in such a good position that fogs would work perfectly.
or maybe make your front turns your fogs, corners your turns and then run your fogs as a low beam, with your regular headlights as a tow stage high beam.
just tossing you another idea
umm teg tips… you can make the bumper lights on constant. you can also make fogs come on without having headlights on.
wite2nr you can always consider reading the god damn thread. I mean it’s just somethin i’m throwin out there…take it or leave it…
yes u can make them stay on like foglights, but u can also have them stay on and they can still signal if wired properly… the only bad news is you are most likely gonna melt the lamp itself “just to throw that out their”
:sucks:
grammar police
i seen a da like that …i like the way the look…
:stfu::nobody::wtf::sleep:
Yea my boy bought it to my attention about melting the lens…
nvm
so you want to put an h1 bulb in the bumper lights and the screw socket bulb in the fogs position? i’m confused… teg tips shows you how to have the bumper lights on constant (making them into “fogs”?), so all you need to do is find a way to wire the fogs separately into turn signals. correct? sheesh don’t get all moody on me, i did read it and was confused, i thought teg tips would help you out.
