anyone without ps
Let Me Answer All Of These For You Guys-
If You Decide To Leave The P/S Rack Alone And Just Remove All Of The Other Components You “Have To” Route The Original Pressure Line Into The Return Hose. Seal Up the System And Leave As Much Fluid In There As You Possibly Can (No Reservoir Needed). The Actual Action Of Turning The Steering Wheel Left To Right Will Pump The Fluid Through The Remaining Lines And Keep The Rack Lubricated.
Or
You Can Swap Out Your Power Rack With A Manual Rack From A 90-91 Civic/CRX. These Are A Direct Swap But You Have To Swap Over The Integra Inner Tie Rod Ends Onto It Or The Rack Will Quite Simply Be Too Short.
I Have Done Several Of These For Roadrace Cars And They Feel Great. It’s Much Easier To Park/Drive Slowly With The Manual Rack But If You Don’t Mind A Workout The Bypassed Power Rack Will Work Okay, It Just Doesn’t Give The Greatest Feedback.
Good Luck All
Soy! :cool:
[SIZE=4]TOFU![/SIZE] :slight_smile:
Originally posted by .J.
[B]hth,
J.
Look at Ryan K’s new shoes!
[/B]
Jason, you’re insane! :uhoh:
I’m a novice, so i’m going to word this really vague …but i think you understand what i’m saying. IF I just talk off Rack. Will i HAVE TO seal everything in that particular fashion that you stated?
So if I just remove the belt, I won’t have any fluid issues right?
SoyRacer: I have heard this suggestion before from others, but was never given a practical method in which to re-route the lines. Have you used an Earls fitting and some hose, or actually some how re-routed the stock parts.
Please Note: This is coming from a guy who wore the same pair of shoes for +2 years…DAMM NEAR EVERYDAY!!!
J.
Don’t mean to be annoying, but can anyone answer my question:
If I just remove my belt, I won’t have fluid problems, etc right?
:bow: to whomever answers…
No you wont have any problems. Unless you need to parallel park. Then you might have problems.
I was attempting this swap today and I see that the shaft is smaller in diameter on the Civic rack where it bolts up to the rear crossmember on the passenger side.
Has anyone else done this swap?
Soyracer, what did you do to remedy this?
TIA
archivethis
With the help of ryank we found out to turn the steering wheel lock to lock on the Civic is 3.88 turns as opposed to 3.53 turns in the G2 Integra. This would make the steering harder at low speeds than just removing the p/s belt.
I am now on a quest to find a manual rack that will bolt right up with a smaller gear ratio. Any help is certainly appreciated:D
