When connecting the VAFC to a PR3 ECU , where do you connect the RPM (Green wire) to? I think it goes to the VSS (speed sensor) pin on the ECU , put dont know…Can you let me know so I can get this thing in!!!
VSS wire is the yellow/red wire on the “B” connector of the PR3 ecu. its pin “B16.” if u needed to know:)
i know where it is
i know where the pin is and stuff but I want to know if that is the one to use for the RPM for the VAFC…VSS? thanks for your help
You’ve got mail.
Kevin:cool: :vomit:
