If you check here in teg tips or here:
http://www.hondata.com/techwiringpw0.html
for an ecu pin out for a PR3 ECU you will notice it is quite nice and explains exactly what wires go where.
My question is… when wiring up the Apexi VAFC, its diagram first of all says to use the H2 diagram (which is the wrong ecu, H1 has the same number of pins and layout), and second, it has VTEC signal and VTM positions in different spots than the ecu pinouts in the forementioned locations (which I trust ). Can someone please explain to me what to do. Is it something really simple that I’m overlooking? Do I just follow the Apexi directions and stick a VTEC signal wire from the APexi unit where one isn’t on the ECU? Please Help:bawl: :bang:
