Alright here’s the problem. I have a ls tranny tha i blew the diff up in and i have a friend with a ls tranny that has bad syncros. Is it possible to take my good syncros and put tem in place of the bad syncros. Or would it be easier just to swap the whole gear set from one tranny to the other.
both will work, but it would be better and cheaper to swap the entire gear stack.
this ofcourse is only if none of the gears were damaged when the dif went out
if you need instruction on how to pull the trans. casing apart i can tell you. doing this will let you get a look at the condition of your gears.
i got a manual that shows how to take it apart. if i cant get a ls tranny would the gears fit into a gsr case.
