Has any one repadded a db1 armrest. Any info would help Thanks
db1 armrest? I have never seen a db1 armrest. I had the USDM armrest in my 92 gs and I repadded it, but that was back in '97. I have 91 ls that I will be putting a armrest in that needs repadding. Do you have the shoehorn armrest or the armrest that is mounted on the floor over the e-brake?
its a jdm da armrest. It mounts over the e brake. What do i use to repad it?
My dad’s business is re-upholstery so I did at his shop with some extra cushion that was laying around. I have a arm rest that I have to re-pad for my 91 ls, so when I do it I will take some pics and send them to you if you have a email
I would like to know what you used as well to re-pad it (foam)
okay thank you
went to a fabric store and got some like 2 or 2.5 inch foam and cut it to fit and glued it back it and it turned out great. you can look and the for sale section and see the tan armrest i repadded.
post any pictures? and how did you get the fabric back on?
It’s the same as a DA
I don’t have any pictures but i used foam also and cut it to the factory shape, then I used super glue to re-attach the cloth. It was pretty simple and straight-foward.
wats ur father business number i just might send that over to be done
How about installing or mounting the armrest if it didnt come with one…
Im attempting to install or mount an armrest in my 91 DA, but the problem is it never came with one so the holes are not there. Im a little sketch about drill the holes in the wrong place…anyone had this peoblem? Any info would be great…
