around how much does it cost to get your ecu tuned?
depends on who you go to. also, to get it dyno tuned or just drive it and tune it. for a dyno, which is the best, around 600 to 800 depending on how much wrenching it takes to get things tuned to the best.
go to a local speed shop and ask them. it’ll vary.
all depends on ur setup to be honest… i think xenocron chips ecus for really cheap …you can send then ur specs on ur engine , turbo, injector size etc etc and they send u a chip like the ones on ebay which u put in ur ecu
[QUOTE=acuralover;2041342]all depends on ur setup to be honest… i think xenocron chips ecus for really cheap …you can send then ur specs on ur engine , turbo, injector size etc etc and they send u a chip like the ones on ebay which u put in ur ecu
http://www.xenocron.com/[/QUOTE]
Xenocron’s chips are not like ebay chips. THe ones on ebay are complete crap. Xenocron can give you what I liek to refer to as an “advanced basemap”. By that I mean it’s a safe estimate based on information you give them, however it’s not to be a final tune. YOu should stilll have it tuned on a dyno to optimize it.
Xeno please correct me if im wrong here.
