hey guys need help with my 93LS automatic. just to make this short yes i have searched but no answer to my problem. so here it is, i noticed that when i try to start my car my cel light stays on for a good minute or so before i hear my fuel pump clicks on and the cel light shuts off for me to start up. i have just replaced my mfr today. though i am still having the same issue. is this problem something else?. aloha and thanks for your time g2ic.
What CEL code is it throwing?
theres no flash on cel. stays on until fuel pump clicks then the cel turns off. after that she starts. i have to have the key on the ll position.
it sounds like it might be your main relay. Your fuel pump wont prime if your main relay is faulty. You can take it out to open up and inspect it. ive read of people haveing issuse with them and fixing them with a soldering gun. seems like the spots of weld crack over time or something like that.
cel and ecu help please
hey guys i’m still having a delay with starting… my cel does not flash or blink to give me any codes?. here’s what’s going on.
the cel stays on for a good minute every time i try to start. after waiting patiently for the cel to shut off it’ll start. so… if my cel stays on for a minute, the integra will not start. do you think my ecu is going?
i have a 93LS auto. any suggestions and help greatly appreciated.
do you have an aftermarket alarm?
yeah i do. i had it 3yrs. viper alarm
i’d probably try to disconnect that first
removed ecu and have it fixed… apparently ecu not going through a start up sequence, so it’s not responding. module maybe going bad. integra will be down for a bit.
