Im doing general mods at the moment but soon i will change my throttle body, Intake maniford, new injectors, etc. i have an LS motor that has nothing but I/H/E. OBD0. 93 integra. I just want somthing to adjust to the modifications and a rev limiter? any suggestions?
Injectors will require a new tune.
Phearable/Xenocron are both known for making good basemaps for people… that is, if you aren’t looking to have a proper dyno/tune session.
my question is why are you Obd0 when you have a 93?
^ That’s a good question, lol. Additionally, my question is why are you adding a throttle body, intake manifold and new injectors? None of that stuff is going to be of any real benefit unless you have some more serious mods. All three of those items are used in order to help your engine get more fuel and/or air. Your stock motor doesn’t need any more fuel/air. You need to do some more serious mods and then it will require those things you’re listing. Your money would be best spent on something from this list:
- clutch
- flywheel
- shorter geared trans
- limited slip
- aftermarket cams
- raised compression
