Sup, Distributor problem. b16a non obd distrubuter not putting out spark on demand. Will spark but only if you play around with the wires. checked with ohm meter to see if it is grounding out…
my guess its the igniter but its only a guess. and guessing is not good for money…
Help guys
Dan k:shock:
First thing that you want to do is check all of the screws on the ignitor and coil to make sure they are tight. You can also check to make sure there is no corrosion or rust on them too.
If that all checks out then you should check your wiring to make sure you dont have a short anywhere.
Are the contacts on the cap and rotor clean??
Are the plug wires still ohming within spec??
Are the plugs still good??
The ignitor wouldnt do that. When the ignitor goes it just stops working right out, it goes from working fine to not working at all.
Later,
BR
