Attention J&s Teg
hey whats going on dude, well i was going to ask you somethings about the brake system real quick.
Ok i took my car to a brakeshop and i had everything checked and they found alot of things ****ed up in the brake system, the master cylinder had a bad gasket like some little rubber round thing, and it leaked brake fluid or something into the brake booster. So i got the booster, master cylinder, propropsion valve and both the front calipers changed.
And the car still did the samething they said, so they ask me who did the brake conversion to my car and i said me and a friend they said they will have to go back and take out the dash and check over the work we did and see if we crossed any brake lines somewhere. What do you think might be the problem?
Do you think i will have to go back to ABS or is this going to be fixable? someoene else said that the brake booster could be adjusted wrong that can be the problem. :argh:
check your e-mail. This can be fixed. You don’t need to go back to ABS. We’ll talk.
