ATTN: Stereo People
I took out my factory unit and installed another Factory unit for a 94’+ Integra. (The one with the blinking LED for anti-theft). My front speakers will not work now. I tried the fade knob but when i fade to the front, it’s silent. When i turn the knob slightly towards the rear, it is at full power. Is there something wrong with my wires? Or the unit itself. Is there an easy way i could fix it?
TIA
radio is beat
my radio stock has a anti theft light thing
Did you cut and connect the wires? or did you just unplug the old one and plug in the new one? If the harness is the same, then it’s probably your deck.
If you cut and connected the wires, make sure you have them connected the right way. But even if you have them backwards, usually there’s SOME sound at least…
maybe the wires on the deck are different. get a 94+ wire diagram for the deck. its probably some wires u have to switch around.
All honda’s/acura’s from 86 to 97-98 use the same wire harness. Color codes also alike. So assumming you pulled out your old deck and plugged in the new one, you’ve probably got a bad deck.
