I have a question? when installing the tach (wire connections) where do i run the green wire from, they say run it from the coil, but as you know the coil on integra’s are internally built in to the distributor where should i run my green wire from???
On the outside of your distributor (top side), there is pair of wires separated from the other mass of wires going into your distributor. One is black/yellow, the other is solid blue. It’s this solid blue wire that you attach your green Autometer tach sensor wire to. Since it is accessable from outside your distributor, you should have no problems splicing into it.
if you dont want to have to run it all the way across the engine the blue wire is in a circular shaped wiring harness next to where your clutch cable comes through the fire wall it is clipped to your fuel injector resistor. All are on the drivers side of the car.I ran mine this way to keep extra wires out of my engine.
Thanks, now where to run the white wire (night light for the tach) what should i connect that to ???
conncet the white wire to the parking light fuse
auto meter-parking lights?
i bought a voltmeter and air/fuel ratio gauge from auto meter… my question is where can i find the wire for the parking lights so i can tap from it??? and where can i get a fused power from?? what color are they??? thanks…
