auto to manual windows
I have a 1990 gs and i have 1990-91 RS door panels i am looking to swap the manual RS panels into the 1990 GS to eliminate the power windows. has anyone done this? i assume the doors are the same i would just need the manual window regulators?
nobody knows… anyone have pics of the door without the panels on? like the exposed window regulator?
u’ll also need the window crank handle. might be easier if u can find someone selling the entire door… and either just swap the door or take the regulator from it. might be able to find one on ebay. its been done tho, but not too many posts of it on here.
yeah when you take off the door panal even with pr windows there is the hole where the manual crank would go… and im sure that it would just bolt on…
doors are same. you need the set up for manual windows though. i have 1 for drivers side without the handle
how much?
its back in va right now, when were you planning on doing it? i need to go back anyways to get the rest of the shit for my car. and i have to find a box long enough to put it in if its the same length as a power window regulator, which i assume it is.
i have 91 rs with manual windows .been looking for power set up , where in ny are you located mybe we can meet up and swap them?/
sounds good. although… i already have my stuff off. i am like 2 hours north of nyc
im trying to go from Manual to Auto. has anybody done this with pictures?:angel:
http://g2ic.com/forums/showthread.php?t=150694&highlight=manual+auto+window+swap
