did a auto to manual conversion and I’m not getting fuel out of my injectors, can hear the fuel pump run but my injectors are not spraying fuel
Fuel in the tank?
Have you checked for fuel pressure ?
If you have fuel pressure in the rail but not getting fuel in the cylinders the injectors are not opening. That is either an ECU or wiring problem.
Got fuel.got fuel pressure. Ecu is good but the wiring I might have a mess any one have a picture of their wiring of the swap
Check to see you’re getting 12v to the injector power wires. Check your fuel injector relay.
