how much from empty does the tranny hold?? liquid amount of ATF?
I think ne where from 2.5 to 3 litres…
Juss top it up, then check the dipstick after :burnout:
It holds 3.2 quarts. Just put 3 quarts in because there is always fluid that wont drain. I just replaced atf last week.
the Tranny hold 4.6 qts total if i remember correctly… you’ll only be able to drain 3-3.5qts max.
