Who is going auto x this year? My first outing is June 11 in Dayton Ohio. Will be updating with some pictures.
w00t! Can you get a drone to follow you? Those are some sweet shots.
I do not have a drone to follow yet. Currently I think im chasing a bad ecu
Ah crap. I ended up buying a new ECU just to have on hand. It took a while to get one for an automatic too. Backup.
I ended up putting in a p28 with hondata. I dont think it was my problem though
What sort of problems are you chasing down? Some of us have encountered just about every single one of them
Well the car was bucking sometimes didnt matter what rpm. Changed the fuel pump that want it. Then i changed the computer to a p28 with hondata s300. I received an oil light that was blinking then. That was the icm behind the fusebox. It was not the problem. So i changed out the whole distributor and i think that has solved the bucking problem. Now though car goes into limp mode cause of a overheating code on the hondata. Im tracking that down now.
We have a limp mode? I didn’t know that.
Hondata has a limp mode. We also dont have a code 11 either it is hondata specific. I have just learned all of this myself. This weekend i worked on redoing the sealer where the tail lights are cause it was leaking. So no engine work.
Ah crap! Thanks for the info.
Out of curiosity - speedometer working? I didn’t realize it during my build but without the ECU receiving a speed reading my car would go into limp mode that was dangerous on the track.
Yes it is working it is 10 mph off but works. It was the icm in the distributor so far. I am fighting the overheating i think its a sensor will find out tonight.
Thank you for the imput i can put that in the back of my brain for future trouble shooting.
