I installed a Scroth Rallye-4 into my DA today w/ an existing Corbeau Fx-1 Pro seat and was wondering if anybody knew how to loop the seat-belt sensor, or just plain do something about the beeping seat-belt warning indicator and flashing seat-belt light in my dash. What can I do to get rid of the beeping and flashing?
I’ve tried:
-Looking for a fuse to unplug = no luck
-Unplugging the system electonically from where the automatic slider is located and from behind the seat where the motor is = no luck (It only disables the sliding maneuver)
-What else can I do besides leaving the stock seat-belt system in there and leaving it plugged in all the time?
Thanks everyone. I went ahead and removed the connection by the passenger kick panel. Under the carpet by the ECU there’s some sort of sensor/seat-belt unit that once unplugged, shuts down the operation of the seat-belts.
yeah my pass. side one won’t retract, and it beeped non stop, so I decided to unplug it one day and just been using them in “manual mode” since then :giggle:
:werd: I guess doing it with the ‘tap’ would still enable you to use the passenger side in ‘automatic’ mode. Errm. I have no problem with the ‘manual mode’ though.
