what camber kits are yall using for autox? i have koni yellows, ground controls, and the gc upper mounts ready for installation and i figured i should probably go ahead and get a camber kit since i’m sure i’ll be needing one. i figure the ingalls extreme kit is the best. (really i have no idea) but it seems to be the best. anyway, thanks in advance for any help.
I’m gonna buy the OmniPower UCA. What is your camber at right now?
i havn’t put the shocks/springs on my car yet so my suspension/camber is still stock at the moment. i was hoping to wait out for the omnipower uca as well but it seems like it’s gonna be a while before they actually start selling them. in one post i read that they’re having problems making them fit on our cars or something.
I use Vision arms on my autocross car to add negative camber.
-nino
i dont use camber kit and i dont think i need one
What class do you run in? I haven’t seen any other DAs at the events in San Diego.
vision arms? i do they make actual DA control arms or are you using another cars?
www.jdmhondaparts.com carries the Vision arms I believe.
If you are trying to get rid of negative camber due to lowering the car, the Vision arms are not what you want to get. But if you’re looking for better autox performance, these are the arms for you.
-nino
Do you daily drive with the Vision arms set at you auto-x setting or changing at the track/day of an event?
Thanks
The arms are set to the least amount of negative camber possible and it’s still at about -3 degrees.
