Yes i searched first! i have a 95 hydro tranny and was wondering if there is a diffrence in splines on the axels on my 91 knuckles and a 95 axel? would like to know before ordering the wrong ones. are all inner joints are the same on Bseries? Thanks for any info.
hope this helps
the passenger side is the same on all integras,i have personally interchanged them it just matters if you have abs or not and if you have a 90-93 mid shaft or a 94 and up mid shaft when ordering the driver side , some one please correct me if i am wrong
No ABS and i have a DC2 intermidiate shaft… im worried about the knucle splines cause on EF’s diffrent years had 1 or 2 more or less splines on the knuckles just wondering if its the same way with integras… so pass is good, but seeing im using the DC intermidiate shaft i should use a 95 axel on the driverside then?
anymore info?
