I need to know everything im gonna need to replace both axcels and where i can get them.
What I need:
-approximatly how much will the job cost
-a miracle
You can get axles at most autoparts stores or your local dealer (much more expsensive). Budget at least $320 (before core refund) for both axles and if need be rented tools. Or if you want to get a shop to do it for you they usually charge around $320 -350 to replace them.
Tools needed stuff needed-
-1/2in metric rachet set or 5/8 will work.
-32mm spindle socket
-32mm spindle nut
-Axles
-balljoint fork seperator or tie rod pawls.
-floor jack
-jack stands
-1/2in drive 18in or longer breaker bar
-A case of corona’s with some lime
-a few friends
- about 3 hrs for the beginner
Have fun!
