Hey guys,
I’ll start off with a story. About two years ago (just looked at my images, date is 9/5/2010!) I was browsing Craigslist for cars to flip when I found two DA Integras together for 500 bucks. Now, when I called him I never got through to him, and he never called me back. THE NEXT DAY, my roommate comes home with THOSE TWO DA Integras. I ended up buying one of them off my roommate for 300 bucks (half the price plus covered his towing). Here’s what she looked like:
The car was “intended” to be a parts car for the owner he bought it off of. Now, This car was in bad shape, but not near as bad to be a parts car. It had a miss that they couldn’t find resolution to. So I figured what the hell, this will be fun! I started with the basic things I needed, like some good used tires to get her rolling, a striker so the door would latch, misc stuff. Then I started with the motor. I chased UP and DOWN, replacing this and that of which already needed to be replaced, I’m talking over kill tuneup :rant:. Long story short, she had a serious chunk of material missing from one of the valves. SO, I did a full head swap (that I picked up for $37 bucks), swapped everything over, fired right up
Here’s a shot of the bad valve:
I went to take her out for her first real drive, put it in gear and took to the street. I forgot my phone at home in case something were to happen so I went to put it in reverse and back up. Damn shift linkage breaks in half on me and wont come out of gear!!! :bang: Got her fixed up, and started daily driving her after about a month of turning wrenches.
After she had been running right I started to clean her up, I buffed the living piss out of this car for a solid week, ruined 8 compound pads in the process. Here’s what she looked like:
Fast forward 3 months. It’s the middle winter now. The oil pan gasket has a leak but I’m keeping a good eye on it. I’m driving to work at 5:30 am, cruising at 60 on the highway, and all of a sudden my oil light comes on, and a noise arises. Within 5 seconds it went from quiet to LOUUUDDDDDD, and I instantly shut the car off. I pulled over and popped off the oil fill; it’s bellowing smoke out of the valve cover :bawl: I guess the oil pan gasket froze up and broke apart big enough to dump 4 quarts of oil, thus spinning a rod bearing…
Times got tough, I moved, it got towed (with a bad motor) by the city and I had to go get it. I was trying to sell it just because I didn’t have time to repair it. It’s an automatic with a spun bearing, I couldn’t even sell her for 600, with a 400 dollar hit for what I had in it. I didn’t even want to sell her, but such is life.
Fast forward a year, I had taken her to my moms and decided I was gonna wait until I could afford to build her back up. Now fast forward again about 6 months or so (losing count now haha), I finally decided to map out a plan to do a 100% rebuild on the motor. Now after pricing everything I found a guy who had a built ls bottom end for cheaper than it would be to rebuild…
My plan quickly spiraled out of control, way off track from what I had intended to do. I had planned to do a fresh bottom end, hot tank the head and no all new seals, slap it on and drive it.
Here’s what I have now:
B18b1 block
GSR crank
Eagle H beam forged rods
ARP Rod Bolts
ITR pop up pistons
ACL bearings
GSR water and oil pump
ARP head studs
Golden Eagle Vtec conversion kit
OBD1 B16 Head:
Bone stock, resurfaced head (within factory spec)
All new guides, seals, cleaned valves and springs
Stock cams
ITR wrinkle red replica valve cover
I’m now in the process of grabbing my parts for a full manual swap (92 YS1) and getting rid of the slushbox!
Swapping full interior to black (getting rid of that ridiculous Palmy Blue!)
I picked up a virgin p28 ecu and I just bought (today) a chipping kit so I can have a basemap for startup and take it to a tuner on a dyno here in town in the next month.
I’m getting super nervous, and excited at the same time. I would be a lot more excited to be putting this money into performance parts, but first she must come back from the grave
I’ll post some more updates later tomorrow if I have time, I’m running to grab the rest of my manual swap tomorrow, so it’ll be a busy day!!
Thanks for reading! I’ll get more in depth of the nitty gritty and the fun stuff the next few posts!
- Brandon
