axle help
does anyone by some chance have there axles out or old one laying around or something.
i need to know how many splines are on the outboard side.
hopefully it will be the same or i will have to use place racing axles :frowning:
ttt
I counted 26
If you are doing an engine swap into an HF CRX or some Civics you might need to use the outside of the old axles on the new axles, it other words,
OLD_____NEW- Trany / half shaft- NEW_____OLD.
I hope you under stand what I mean. You will have to buy axle rebuild kits to do the job, They come with CV Boots, grease and clips. It’ a pretty easy job. Email me if you have any questions.
All I had around were inside Axle halfs they counted 27 splines.
The easy way is to just change the hubs.
its going in this
i have already swapped the hubs once for bigger brakes and i just rebuilt the calipers. i really dont wanna do it again :(.
but i suppose if i have to its still better in the end than being raped by placeracing.
