Axle lengths... auto vs manual??????
I recently started hearing a lot of clicking from my driver side axle when turning… It had progressively gotten worse. Late on bills and short on cash, I checked good old Craigslist… I found and bought a set of axles.
I’ve been up for hours at this point researching to see if there is a difference between automatic and manual axles or if there is even a distinction. the best I found at this point is vague guesses.
as I read, I understand there is a difference in the camshaft between the GSRs and the other Integra trim packages. but have not at this point found anything conclusive as to whether or not the axles themselves are any different or the half shafts are any different between automatic and manual.
I figured I’d run over to autozone and see if there is a distinction between the axles. If not I’m going to assume that the half shafts are the same as well. but if someone on this forum actually knows that would maybe save me a little bit time and energy running around and doing all this crazy nonsense for nothing. thanks in advance for any info or insight that anyone might be able to get me.
this is the only post that seems to fit your bill
http://forums.g2ic.com/showthread.php?106165-axle-information-spline-count-length-weight-compatible-civic-axles-etc
structually the axles are the same length . the bearings are a tad different on the inside
Thanks for the help, and the link.
