axle squeaky noise...
so i recently had change the driver side axle with a brand new one, but then now when i turn left or right it makes this loud squeaky noise…why is this happenin?? do anybody can help me with this…thanks
Can you describe the sound any other way than squeaky? Is it a rubber bushing type of squeak, a metal on metal noise, etc.? I did an axle swap and inadvertently bent the brake disc dust cover a little bit near the lower ball joint. When I turned it would scrape against the brake disk and make a pretty bad metal on metal grinding/squeaking noise.
