NEW VIDEO/SOUND
Up until tonight I have been going fairly easy on the throttle, I decided to try my luck with an Italian tune-up and went for a couple good hard WOT pulls onto the highway through 2nd and 3rd. Once I get going the wobble and sound goes away (possibly because I’m just ripping and my turbo sounds like an airplane taking off and I can’t notice it). Turns out it went well and nothing went wrong or broke but the problem is still the same. Next I decided to try and get a better video of the sound when it is most pronounced and I did have some success.
In the following video I had a hard time picking out the particular wobble sound with my laptop speakers, but then I threw on a decent set of headphones and it’s very clear. Hopefully one of you can help me identify the cause.
https://www.youtube.com/watch?v=cxOyS4ZIBUs
It kinda feels like its coming from right under my left foot. The front left LCA bushing is slightly torn, that couldn’t make this big of an impact could it?
UPDATE
I replaced both axles with new non-reman cardone ones, then replaced the intermediate shaft with a DC shaft and DC driver side axle, took it in for a wheel alignment and everything was pretty much perfect already and all the suspension components are tight and in decent shape. The motor mounts appear to be in good condition and when I try rocking the motor back and forth there is very minimal play (the upper driver side mount shifts a couple mm side to side).
For the most part the problem occurs only when I am accelerating in first or second gear from about 3k rpm to about 6k. I don’t seem to get any sort of wobbling or clunking when moving at a constant speed or during high speed acceleration. The problem is more pronounced when going uphill. Also, it doesn’t seem to be as bad when the engine is cold.
This particular problem of mine started about a week ago when I made the mistake of not slowing down enough to go over some pretty hairy train tracks.
The crash of my front subframe onto the ground was pretty gruesome and almost right away I was left with a kind of clunking sound that only occurs during acceleration.
I cautiously got the car home, got it in the air and took a good look around too see if I could identify the problem. It looks to me like the passenger side axle is the culprit as it appears to be wobbling on the end that goes into the tranny.
Maybe this the result of what was an old differential that was starting to go bad and the impact jarred it to the point of no return?
It’s a 92 Integra GS with a turbo LS/VTEC and the original YS1 transmission.
The horrible sound only seems to occur during acceleration, under load.
In car acceleration (difficult to hear the sound in question, I will try and get a better video later).
http://www.youtube.com/watch?v=Gqo2Q8Uj-pE
Thanks for any help or input you can provide!
