b16 alternator q's?
i need to replace my alternator in my integra, its got a b16. ive searched and found out that a 90-91 alternator will supposedly fit, can anyone confirm this? and do i also need the 90-91 belt?
however, would a del sol vtec (b16) alternator and belt work as well? id like to know which route i should go, are they the same alternator? or do have the same mounting points and belt lenghts, thanks all who reply
b16_integra@hotmail.com
Here is the info on what I used when I did my swap. If the motor is installed you will have to pull the driver side axle and half shaft to get teh alternator out and back in.
31100-PR4-C02RM Alternator $296.66 92-93 GSR
The “RM” after the P/N means remanufactured. Honda / Acura only sell OEM Denso rebuilt units they are just as good as new. If the part didi not have the remanufactured sticker on it you would 100% think it was brand new. I thint they only reuse the housing and the main shaft, everything else is brand new.
31110-PR4-A05 Alternator belt $12.70 94 Del sol Vtec
