hey i have a bunch of questions and i was hoping you guys could answer some. if you have some questions you can ask here too.
- can i use an ls power steering pump and pump mounts on a b16a motor?
- is there any differance between the two?
- what is the easiest way to get the cam gears off without distroying the cams?
- how much hp will my blacksheep b16 have?
ok, im jokin bout 4 but still if you know about the others share your info.
