B16 LSD Tranny in a DA9(Axle Help)
I just changed both of my axles for my car and whenever I tryed and takeoff or go in reverse it doesn’t go. I bought 2 new LS axles. Either i’m not using the right axles or I didnt put them in right.
This is clearly an installation problem.
Are you using the LS intermediate shafts? Are your axles installed flush on both ends? A picture is worth a thousand words.
Yes I am using intermediate shafts. I dont know what you mean by if there flush on both ends. I’ll try and get a picture up
I’m betting that you didn’t push the axles into the trans (intermediate shaft, on the driver side) far enough to lock… and then when you put on the axle nuts they pulled out of the trans/shaft… so your differential isn’t grabbing the axles.
When installing axles you gotta shove them into the trans until you hear them Click and lock into place. If you don’t recall hearing that, I don’t think they’re installed correctly.
Thank you guys for all the advice. You guys were right, just a user error. My passenger axle wasn’t completely in but my driver side was. I was scared i messed up my LSD. I gotta JDM B16
