b16 swap from ls
Hey guys I’m having problems with my axles. I bought a frist gen b16 to put into my 91 LS. i drop the motor in and everything but the axles are not fitting, there like to long and I’ve made sure that there all the way in the mid-shaft. I know that these axle are the ones that everybody uses when they do this swap to there teg and it works just fine. Is there something that I’m doing wrong and has this ever happened to someone else. Any help would help a ton-thanks
Re: b16 swap from ls
umm u using the stock integra axles from your car?
umm too long how? it should work fine if u using the stock axles from your teg
I am using the stock axles for my teg but there not working. It’s probably something stupid. These axles are supposed to work
