b16a bad oil pressure sensor????
well i think i have a bad oil pressure sensor on my b16a cuz im really hoping that its not a bad oil pump, so i was wondering…since the b16a is an obd0 motor, is there any other USDM obd0 motor that has the same oil pressure sensor? I know the b16a is the same as from the 99-00 si’s but i dont want to have to switch the connectors.
so does anyone know if there is another USDM obd0 motor with the same oil pressure sensor?
did you test the sensor or are you just guessing?
how does i test the sensor?
this is how
