I have a 90 teg with a b16 swap and i need to know if the stock intake for the 90 teg compatable with the b16 motor…thanks for the help!..
:squint:
Are you meaning the manifold? if so, no.
If you are meaning the tube, I squint again at you.:squint:
Originally posted by H4-DB1
[B]:squint:
If you are meaning the tube, I squint again at you.:squint: [/B]
sorry man if i wasnt specific…but i need to know if the ports on the 90 teg tubing compatable with the b16 motor…will it work?..thanks again…=)
ports on the 90 teg tubing? are you talking about the intake manifold plenums? the ports in the head? or the size of the throttle body and intake piping.
here is some info.
-your stock intake will work fine w/ your b16a (an aftermarket one will fit too…if it fit your original motor, it’ll fit now too).
-you can NOT use your b18a intake manifold on the b16a head. it just won’t bolt up…the stud pattern is different.
