basically i have worked as far as the 3 black sensors in my dist being the problem .[crk,cyp cam] correct me if im wrong please.
reason im asking is my second dist gives nearly the same readings are these sensors a common fault ?
with the harness disconnected i get 5-6 volts on one set of wires and 0-1 volt on the second set and 0 -1 on the last set .
from what i have been reading all 3 sets should give roughly the same reading .
can i purchase those sensors or is it cheaper to get a whole new dist ?
please mention suppliers if you have a good one .
thanks
mark
