system
July 11, 2002, 7:25pm
1
Just did a b16a sir1 swap and I used my old ls distributor with the b16. I was only able to get 1 bolt on to hold the distributor. Oil is leaking from it pretty bad. Tryed a new “o” ring with no success.
Where can i get a cheap distributor made for the b16a sir1, or a used 1.
PS I hate ebay!
Thanks!
system
July 11, 2002, 11:01pm
2
Im runing a bootleg setup w/ls dizzy right now
and I got no leaks. Im also using only 1 bolt
through the top.
I know you changed the o ring and said no luck,
is it possible that its not completely bottomed out?
You can snoop around for a dizzy at
www.thepartstrader.com
system
July 12, 2002, 2:33pm
3
You have to cut off a leg…
off of the LS distributor, that way you can at least use two bolts to hold the distributor on, otherwise you have two options:
Find a B16 distributor, usually run about ~$150
run the car with the oil leak.
-Jeff C.
system
July 12, 2002, 4:50pm
4
Thanks for the reply’s. I made sure the “o” ring was snug twice, still leakin.
I cut off 1 of the legs but I can’t get 2 bolts to fit. I think I will spend $150. I’m very anal, can’t have any leaks!
Thanks
