I broke my knock sensor when I put the b16a motor in my car. I need to know which knock sensor I need to replace it with, help me please. Also if anyone knows how to run the vacum and fuel lines on this swap, my engine isn’t kicking over and I think that this is the problem. I need some help guys, thanks.
you can use a 92-93 gsr knock sensor form the dealer. fuel lines are easy to hook up from what i can remember there is only 1 place where it goes , and the vacumm lines are also easy its just look complicated but its not if you take it step by step… look underneath your hood there is a diagram that shows each path for the hoses. if not, do a search on helms manuel some member on this board was nice enough to download the whole book for us =o)
