B16A running rich
Problem: Running rich ie: black smoke, poor gas mileage, carbon buildup on rear and rich smell from exhaust
Setup: 1993 integra B16A (came out of an ob0 integra not sure before that) Im using my stock wiring harness, stock (b18A1) injectors, p28 ecu, MSD ob1 distributor with external coil pack
Things ive done: new O2 sensor, new wires and plugs, checked vacuum hoses, checked resistance on fuel injectors, and no exhaust leaks
I know the p28 isnt as good an ecu as a p30 to be running but would getting a p30 really make a difference?
i think i would check, timing?, timing marks?, fuel pressure, injectors sticking. considering the things u have allready changed/checked
does the car run rough at all? or just rich?
timing marks should be ok unless a tooth slipped ive dicked with the distributor coutless times doesnt seam to make a difference i guess timing marks are fuel pressure will be next
it does seam to feel like its “missing” sometimes cruising down the road
will test some more and get back
Put in injectors from a b16a2 and check tps same problems
bump
unplugged a hose off the MAP and plugged it back in and it runs fine now…piece of carbon was trapped or something…
