b16a wiring
Hey guys,
My jdm b16a is installed but its not running the way its suppost to. My mechanic is doing all the work , i provided him with all the info he needs so he can add the 4 extra wires. I was wondering if someone has a simple diagram on where and how to add the wires in the ecu and on the engine. I think pictures is the best way rather then a excel spreadsheet.
Any help is appreciated.
Elias
90 ls
your plugs at the ecu are where you have to add the pins for VTEC.
A is the biggest plug. The B is the smallest. The other is D
You will notice that these plugs will be missing pins in the locations that you will be adding.
A4-
D3-
D6-
These are where you have to add pins.
I just did my swap this weekend and i have no codes!!!
g2turbo
A4- ← what is this
D3- ← "
D6- ← "
One more question G2turbo. Is there any more wires that have to be switch like the P/S pressure switch, I have a 90 Integra so that’s why I’m asking before i drop in all this wiring.
I don’t have a scanner, and I’m not very good at doing ASCII diagrams otherwise I’d show you here, but go out and get the June 2002 issue of SportCompactCar. it should still be on the newsstands. on page 168 they have a pretty good diagram on how to wire the four components you will need. they got it from hasport so you may be able to find the same diagram on their webpage. hope this helps.
