B17 ECU connectors cut from main harness
Are the vtec wires still on the main harness if the connectors were cut?
Counted them up and i seem to be missing a few.
Refering to Helms manual section 11-33
C437 seems to be all there seeing there are 12 wires and 12 in the helms. (no vtec wires listed)
C436 i have 12. there are 14 in the manual
C438 im missing one.
the ones that im missing seem to be vtec wires? idk if you look at helms sect. 11-33 there are 3 vtec wires total. 2 for C436 and 1 for C438.
Does that mean vtec wires arent part of the main harness?
vtec wires, as far as i know, are not part of the main harness. i guess you could just make your own subhaness with a spade connector and soe wire and be done with it. that’s what i ended up doing.
argh looks like i have to add the vtec wires… so i guess it wont be a plug in process. thanks for the reply
new question:
If i were to get get a b17 engine harness, would i still have to add the vtec wires?
you would have to run them from the engine harness to the ecu if the car wasnt vtec to start with.
RS/LS/GS - NO vtec wires in main harness
GSR - vtec wires in main harness
This means you can’t use a gsr engine harness with an rs/ls/gs main harness. Reuse your stock engine harness, run the extra wires from the ecu through the firewall, install a stock connector to these wires.
Run the extra wires needed on the engine itself, follow stock routing. Personally I suggest ripping apart the stock loom and adding your wires to the stock ones. Gather all of these wires in one spot. Install the other half of the wiring connectore (remember the one you put on the wires you ran through the firewall).
Now you have a stock looking engine harness and only one extra connector which needs to be disconnected when removing the engine.
great info… more then i wanted to type:werd:
colin i emailed you before about using the LS engine harness into db2 main
I didn’t get an email, unless you’re talking about one from a long while ago… In case you’ve got the wrong address - 1colin (at) gmail (dot) com
it was a while back say 1 month
so youre saying to pin it through to the driver side connector main harness?
So after counting wires up and obtaining spare ecu connectors from a 92 5spd, i found that the number of wires in the DB2 match up to the number of wires of the spare connectors. Does that mean the vtec wires arent in the main harness?
anyone have pictures of their gsr ecu to main harness?
As I stated, the RS, LS, GS cars do not come with ANY of the vtec wiring. I’m not sure why the wire numbers are the same, possibly there are some other components which the B18a uses (an extra solenoid maybe?).
  1. Follow the steps I already typed in regard to creating a sub harness which runs from the engine to the ecu.
  2. Use the ECU plugs you have, detatch the back of them and remove a couple of the wires with the actual pins attached. Solder these to the wires at the ECU end of your sub harness.
  3. Open up the ecu plugs on your stock main harness. Insert the pins you just soldered on (in the correct location of course).
Your vtec wiring is going to be completely separate from the stock main harness. You are creating a sub harness. You could try to run them in the stock main harness but that would be a LOT of work. You’ld need to un-loom the entire thing, run the wires, remove/add different plugs, change pins on various connectors…etc…etc…
If you need some more specifics about which pins are which → Engine Swap Guide (found in the Teg Tips section - not the forums).
For more info about de-pinning and pinning ecu plugs —> google search and H-T search. There are a couple site with instructions and photos posted (I don’t know them off hand). Or just mess w/ the extra plugs you have, since they’re extra you can break them in the process of learning how they come apart and the pins come out - then you should be OK when reinstalling on your stock plugs.
this is gonna be a pain. seeing that there are some wires that are the same color and go to different spots… how to differentiate? No clue…
It’s not that difficult with a multimeter (use to test continuity) and the Helms manual…
